I've had the 160 for some time now. With the same system in the same car I have hit as low as 142 and as high as 162. What I have found is it is temparature sensitive.
When temp is moderate i score the same as my local shops meter. Cold i do less and when the car is hot as hell in the summer I max it out.
Edit: I have mine wired to a cig lighter plug so I can pull it toss it in another car whenever.
Edited by alvitae
Ever think that the temp is more affecting your amps and batts.
d(-__-)b
reason i'm asking is i'm thinking about getting one of my own so i have a genral idea what i'm hitting. i'm also putting a bigger alt and new pwer wire in 2 morrow. so if i test it again with the inside temp cooler it should read higher
Team DBs (Driven By sound)
  • Who's Online   1 Member, 0 Anonymous, 2061 Guests (See full list)
