Maroon97SL Posted July 13, 2010 Report Posted July 13, 2010 Debating on doing the big 3. My build plans so far are AP 15001D, 2 12" eclipse subs 8ohms @ 300 watts, custom box. I will be running this amp off of a stock alt and battery ( think the alt is anywhere from 85-100 amps ) and the big 3, will this be substantial enough to run that AP safely? Will be doing the big 3 with 1/0 gauge wire and a 1/0 gauge wire running from the battery to the amp. 2000 White Saturn SL2 Kenwood KDC-248U Head Unit 1 Rockrod Fosgate HX2 punch DVC 12 1 Rockford Fosgate R500-1 amp Stock Mids & Highs. Budget Build, I spent about 330$ for the setup. but its a crx, if you cant fart and do a 150 in a crx there is something wrong...
rubbernutz1 Posted July 13, 2010 Report Posted July 13, 2010 idk if it will be enough to make your set up work good, but it definately wont hurt it can only help
Maroon97SL Posted July 13, 2010 Author Report Posted July 13, 2010 idk if it will be enough to make your set up work good, but it definately wont hurt it can only help So maybe a different amp? ATM everything is stock, running a 4 gauge power wire to my pyramid 2-ch 1000 watt amp and my lights don't dim at all. 2000 White Saturn SL2 Kenwood KDC-248U Head Unit 1 Rockrod Fosgate HX2 punch DVC 12 1 Rockford Fosgate R500-1 amp Stock Mids & Highs. Budget Build, I spent about 330$ for the setup. but its a crx, if you cant fart and do a 150 in a crx there is something wrong...
BJD3 Posted July 13, 2010 Report Posted July 13, 2010 So maybe a different amp? ATM everything is stock, running a 4 gauge power wire to my pyramid 2-ch 1000 watt amp and my lights don't dim at all. That's because that amp is probably only producing an actual 500 watts. I'd at the very least toss an decent sized battery in back along with the big 3. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
Maroon97SL Posted July 13, 2010 Author Report Posted July 13, 2010 That's because that amp is probably only producing an actual 500 watts. I'd at the very least toss an decent sized battery in back along with the big 3. Alright ill keep that in mind man, thanks. 2000 White Saturn SL2 Kenwood KDC-248U Head Unit 1 Rockrod Fosgate HX2 punch DVC 12 1 Rockford Fosgate R500-1 amp Stock Mids & Highs. Budget Build, I spent about 330$ for the setup. but its a crx, if you cant fart and do a 150 in a crx there is something wrong...
keepinitloud Posted July 13, 2010 Report Posted July 13, 2010 do the big three add a second battery and you will be fine till your ready to add an alternator 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Maroon97SL Posted July 13, 2010 Author Report Posted July 13, 2010 do the big three add a second battery and you will be fine till your ready to add an alternator Im just gonna keep saving till i can do this all at once. I make minimum wage, work 3 5's a week and have bills =\ economy sucks ass. 2000 White Saturn SL2 Kenwood KDC-248U Head Unit 1 Rockrod Fosgate HX2 punch DVC 12 1 Rockford Fosgate R500-1 amp Stock Mids & Highs. Budget Build, I spent about 330$ for the setup. but its a crx, if you cant fart and do a 150 in a crx there is something wrong...
