Fusing shorter power wire from bat to amp
If you have a battery in the trunk, and you're running about a 3-4 ft 1/0 power wire, where on that wire would you want to fuse? Closer to the battery correct? Within 18 inches? Is that just a standard rule? Can if be closer, say within like 4 inches? I just don't want those big ass knu fuse holders in the center of my wire if that makes sence.
sorry for the fheg question
2006 Nissan Z Track.
My Feedback Thread
within 18 inches of your Amp, that is also part of MECA rules just a little fyi.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
AFAIK, it can be as close as you want it to be, but it shouldn't be further than 18 inches away.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Are you sure about that. I just glanced over the rulebook online, and all it says is
Fusing or manual reset circuit breaker(s) must be located within 18" of battery termination
Page 34
AAH. NVM. I found the rule.
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
Look @ page 8 number 4
4. In-line fuse(s) must be placed immediately before the subwoofer amplifier(s) a maximum of 18” from the amplifier(s) and all positive power
wires leading to the subwoofer amplifier(s) must be fused.
06 Impala SS
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
  • Who's Online   0 Members, 0 Anonymous, 2053 Guests (See full list)
