Looks like a car of a endtime movie, put a H/O alt in its to hear in the sound that ur elecrical can use 2 or 3 more volts.
i have a iraggi h/o and i never go below 12.5v its just where i recorded it and me not knowing much about stuff the app i used to make the video had to bump the quality down a whole lot and it caused some distortion but i assure you its clean on my end.
Looking good man, but if the camera isn't distorting it isn't loud enough :drink40: With your 280a the volts should be dropping when you go full tilt. The car and one 3000 can burn through that 280a alone. You should figure 50a for the car which leaves 230a for the amps or 115a each which is less than half of your full draw.
It's not a bad thing, you just need to keep an eye on the voltage, but there should be a drop. If you don't see one at all then your amps are turned way down and it will go louder or you need to move your volt meter to those rear batteries.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
