Autruche's Saab 9000 Build - New box started!
You say you suck at fiberlgassing and you made your door panels look like that? Man you are a god compared to what I could do. Lol.
Keep up the good work with everything. The sub box will be awesome as will those pillars. I'll be keepin an eye on this.
I like the oldschool one..
Current System: Stock 2011 Tahoe
Loud as F**K
Just kidding
After cleaning out the car, later that night I went out to get the lower back seat shape traced onto the door panel, so that the speakers don't hit the seat. After I put the seat back I noticed this gap.
And I was like :yahoo: There's enough room to set the front of the box up just how I want to.
Then after I traced the back seat onto the door panel I decided to lay it out and take some pics of how I'm going to lay it all out.
Both doors together.
Tomorrow I'm going to see about getting started on my box. And I might... MIGHT order a circle jig to use with my dad's router, then I can get started on my doors.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Those door panels were nothing, Not even really fiberglassing, it was just resined polyester. I've never molded anything into something else, like molding the fiberglass into the door panel, as those were built to be two pieces. The most important part of the glassing, as I've learned, is building a proper sturdy frame to glass to, it all goes smooth then.
My Saab 9000 build
Started doing some work, but it's just too damn cold to stay out there and keep working on it. I'll get back on it earlier tomorrow and get started on the floor and start doing some of the fun shapes for the side. My goal is to have the box done by the end of the month, then I can start on my doors. :yahoo:
Anyway, here's what I got done.
And The back seats still work fine.
My Saab 9000 build
  • 1 month later...
Well I just got a package in yesterday...
Hmm... I wonder what's in here...
I get all of my stuff from ebay shipped to Dr. Travis Walker, lol.
2 of what?
Ah, spools. Most likely spools of wire, but what kind and how much?
Ah speaker wire. How much and what size? 14 gauge (more like 16 gauge) and... One thousand feet! Not dicking around.
Yeah it's eBay crap wire, but hey, it's a thousand feet and the highest amount of power that will flow though a line is about 120 watts anyway, as I'm doing 1 run for each speaker.
My Saab 9000 build
  • 1 month later...
Well, a little update:
I started working on my switch setup for my windows. About a year ago I replaced my driver side front window regulator and motor and then my central locking and window control unit took a shit on me. So I had all working windows, but no working switches. So I decided to fix that. I got 5 DPDT switches and went to town on them, and this is what I got.
All wired up
Had to bridge all of the connections. Basically a mini buss bar now.
All hooked up in the car.
And, what the hell, a short vid showing it all in action. Not really impressive at all, but it had to be done.
http://www.youtube.com/watch?v=ISUNki-PvhI
I just have to hook it all up to the factory relay and finish the switch panel up and then the only thing left to do is get the motor going. Then I'll be :yahoo: and it'll be back to the build! But before I get the motor reassembled the A/C pump needs to come out and my second alternator needs to go in.
My Saab 9000 build
lookin good. and sound like you have a ways to go.
2 12" memphis mojo mojo12d4
hifonics brutus bxi 2610D
1/0 power wire
4 gauge speaker wire
ddm tuning 8000k 35w hids
C&D technologies battery (100 ah)
custom box tuned to around 45hz(designed buy fritosaregood)
2010 kia forte koup
Well, once the windows and central locking are fixed, then I have to take the turbo off and clean it out. Then I have to pull the head off and have a dye penetrate test done on it and if it passes I will have a few thousandths machined off to make sure it all level. Then I have to free up a stuck cylinder. Then the whole top half of the motor is being rebuilt. The gaskets anyway.
Then, as soon as I can afford it, I am going to rebuild the lower end of the motor with new rings, gaskets, seals, and bearings. I may even pull the head off again to do the whole valve train.
Basically, it will have all new internals by the end of the year. I want a solid reliable car before I start dropping thousands of dollars in audio in it.
My Saab 9000 build
  • 4 weeks later...
Look what I picked up for a hundred bucks:
An RE MT 15. Only thing I hate is the fact that there are no specs available for it cuz they are built to order. Planning on doing 4.5 cubes, at 28 with as much port area as I can get. Got a real POS amp to throw on it for now, and maybe a small upgrade later. It seems to like playing in the mid 20s so that makes me very happy.
My Saab 9000 build
