justinadams Posted July 20, 2010 Report Posted July 20, 2010 ok. so i've got a factory system i really would like to keep. but i would like to add a sub. and i have no clue what i need. seeing as the amp i'm gonna get only has rca inputs. and my factory head unit does not. i'm not looking for an equalizer. i just need something good that will output bass to my amp. i'm just adding a sub and amp to system. no more speakers. and i also was told i would have to unhook one of my speakers to install something like this. is that true? 2 12" memphis mojo mojo12d4 hifonics brutus bxi 2610D 1/0 power wire 4 gauge speaker wire ddm tuning 8000k 35w hids C&D technologies battery (100 ah) custom box tuned to around 45hz(designed buy fritosaregood) 2010 kia forte koup
justinadams Posted July 20, 2010 Author Report Posted July 20, 2010 ok. what is a good one that isn't gonna break the bank? 2 12" memphis mojo mojo12d4 hifonics brutus bxi 2610D 1/0 power wire 4 gauge speaker wire ddm tuning 8000k 35w hids C&D technologies battery (100 ah) custom box tuned to around 45hz(designed buy fritosaregood) 2010 kia forte koup
Bigballa39213 Posted July 20, 2010 Report Posted July 20, 2010 Audio Control 98 Chevy Blazer 4 Door Stock Everything The New Setup 1 - Pioneer AVH-P5200DVD 1- Pioneer DEH-80PRS 2 - Blues Audio 5.25 Mids ( On the dash ) 2 - Blues Audio BL8.0C Components ( In the front doors ) 2 - Blues Audio BL8.0 Woofers ( In the rear doors ) 1 - Linear Power 952 ( Dash ) 1 - Linear Power 2202IQ Modified ( Components ) 1 - Linear Power 3002 ( Rear Doors ) 1 - SoundStream XBP-10 Processor 1 - SoundStream BX-20Z 2 - SoundStream DTR1.3400D 4 - RE Audio SX12D4
Rockbrook Posted July 20, 2010 Report Posted July 20, 2010 i mean theres really no certain brand, all of'em are basically the same and prices vary from where you buy, so just google line output converter i wouldnt spend more than $30-$40 on one personally. and yea if you want the "best" go with audio control like he said but i've been using some off-brand for 3 years and no problems yet
justinadams Posted July 20, 2010 Author Report Posted July 20, 2010 ok. thank you. and am i correct in thinking that i DO NOT have to unhook a speaker to do this? 2 12" memphis mojo mojo12d4 hifonics brutus bxi 2610D 1/0 power wire 4 gauge speaker wire ddm tuning 8000k 35w hids C&D technologies battery (100 ah) custom box tuned to around 45hz(designed buy fritosaregood) 2010 kia forte koup
andym85 Posted July 20, 2010 Report Posted July 20, 2010 yea...just get a LOC...i actually just used the one below on a recent install http://www.woofersetc.com/p7368/SGN11--Stinger-Fixed-Line-Output-Converter.htm you just need to tap into the rear speakers to hook it up two gray wires go to positive/negative on one speaker two black wires go to the positive negative on the other speaker and there is one wire to ground it (again...just splice into the speaker wire to do this, not unhook them) as far as a remote turn on goes....you can either run one straight from the battery and put a switch on it or do like i do just get a dmm out...and test some wires under the dash. -turn the key in the on position so everything has power -put positive lead into a wire, i usually use one under the dash (try a solid pink wire first, or pink with a colored stripe) -wire should read 12volts or so (if it doesnt, pick another wire) -turn the car off -put positive lead back into the same wire -it should read 0 volts -you have now found a ignition source to tap into for the amp remote wire (you will have to have the negative lead of the dmm grounded somewhere on the vehicle during this) i likes me some audio stuff...
justinadams Posted July 20, 2010 Author Report Posted July 20, 2010 thank you. very infomative. 2 12" memphis mojo mojo12d4 hifonics brutus bxi 2610D 1/0 power wire 4 gauge speaker wire ddm tuning 8000k 35w hids C&D technologies battery (100 ah) custom box tuned to around 45hz(designed buy fritosaregood) 2010 kia forte koup
