teamSPB Posted March 31, 2011 Author Report Posted March 31, 2011 Some VERY poor videos of the vehicle playing.... Few things to point out...I was in my garage while playing this so couldnt turn it up fully as the neighbours will go physco, secondly the doors have about 10mm worth of deadening on them so are pretty stiff! And thirdly...only one battery was hooked up! Quick walk around Alt setup now braced up! Compared to this! teamSPB
teamSPB Posted April 7, 2011 Author Report Posted April 7, 2011 wish I had more time to crack on with this! I put the fuse rack in and thought I would see how it looks Also decided it would be wise to put a relay in for the remote turn ons....afterall, the headunit will be trying to power; 10 amps Epicenter Voltmeter Bridging module and God knows what else.... All connections properly secured, crimped in place first, then soldered, then heat shrinked Put them into the holder and job done...one easily removable connector for the relay Oh and the 12v has now GONE! teamSPB
Supercharged DCs Posted April 7, 2011 Report Posted April 7, 2011 Looking amazing, I want to see this thing playing at it's full potential! Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
teamSPB Posted April 11, 2011 Author Report Posted April 11, 2011 Battery rack being built Sprayed black Test fit Had one of the batteries on charge...an hour after it came off charge this was the floating voltage My buss bars also showed up after a little delay Earth bars are 50mm x 12mm Positive is 100mm x 12mm The eagle eyed amongst you may have realised the amp layout has changed also I may post more later...see how I feel teamSPB
teamSPB Posted April 11, 2011 Author Report Posted April 11, 2011 10 batts for now...more if needed..im sure I can squeeze in another 5-8 at a guess
