So long story short, someone turned my gain all the way up on my new amp and I didn't realize it until I noticed all my music sounded really dirty, right before my sub shut off. well I got really pissed, already knowing that my sub was gone, and checked the ohm load, it's supposed to be wired to 1 ohm, well I checked it and it said 19. So I took it out and checked both coils, one said 2 the other was going between .7 and 3 moderately fast(I have witnesses). Well I woke up this morning, in denial, and checked it again, first one said 2, second one said 2. took it and hooked each side up to the home stereo, both played. Now as happy as I am, I got pissed and posted a bunch of stuff on facebook about the person that turned my gain all the way up(childish I know, I removed it and apologized like 10 minutes after) so I'd like to know if anyone could explain what could have happened here.
Start out boxy, shape as you move along.
Dc Audio
Team Fur
well it sounds like a blown coil but maybe its just a bad solder joint on the terminals.
Your voltmeter was not on the right setting. Maybe the wires on the voltmeter are faulty? I say this cause my bro had some wires that were connected by magnet and the magnet was causing some rise and fall of the ohm reading. Glad they are ok man.
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
you were drunk and dreamed about it lol, maybe the coil was still warm and not read right. did u push it in a bit and then test it?
Fresno, Cali 559
That's what I thought at first, last night. I checked all the leads, no discoloration, solder was fine, terminals were tight, and I could even smell burning wires. I just don't understand how it could go from EVERY SIGN of a bad coil, to perfectly fine.
It was on the right setting, I checked it while it was still wired in the box, and then took it out and checked it. AND it wouldn't play AT ALL last night.
I don't drink so that rules that out. Why would the coil being warm effect the amount of resistance in the coil?
Edited by vengfuldev
Dc Audio
Team Fur
no, when a coil dies its very common for the numbers to jump around like that.
the only thing heat would effect is size. things expand when heated so it COULD be possible that once heated the coil shorts out. just a theory. i would expect that sub to be on its way out though. will probably die again and not come back.
I'll find out for sure next week I guess, I've just never heard of this happening, but not even 2 minutes after it shut off I pulled over to check it out and the first thing I did was check the temp on the cone and it wasn't hot at all, I could tell it wasn't ambient temperature, but it wasn't hot.
Dc Audio
Team Fur
Ive seen poorly soldered leads under the dust cap that cause that same thing
usually aluminum voice coils are a lot harder to do a clean solder than copper
so if you were clipping the sub to all hell, yeah you would read a higher impedance due to coil heating
But 19 ohms? I've seen maybe .4 above nom. impedance. I'd rip the dustcap off to check, but it's working fine again, so until then.
Dc Audio
Team Fur
  • Who's Online   0 Members, 0 Anonymous, 971 Guests (See full list)
