Battery relocation
Im moving my battery to the trunk. Im using a terminal from a BMW(they have the batt under back seat and a terminal under hood) to connect the alt wire to and run 0 gauge from that terminal to the trunk. The question is, if I have only one wire from alt to terminal, should I still use 2 runs from that terminal to the batteries? Or is it pointless?
SMD Super Seller
My Feedback Thread
If you're moving your stock battery from the hood to the rear, and not replacing it with any storage unit, then it's a matter of length. Just run two to the terminal from alt, then two to the back if it's HO. If not, then run one to the terminal, then one more from alt to battery. You had the right idea.
Need an install? Hit me up.
[email protected]
You talking about through the firewall or logistics altogether?
The alt is tucked in the intake manifold, under the throttle body. I'll find a pic.
http://customerpics.americanmuscle.com/viewimages.php?sku=56015&id=9579
The space behind the alt is very small. I had force it into place and hold while my boy got the bolts started when I did my big three.
SMD Super Seller
My Feedback Thread
Hmm...well doing a 2-5 foot run would easily carry over 300A on one 1/0 wire. Running dual wires off the post is your best bet in this case like you mentioned.
That your engine?
[email protected]
yeah... really no point in having 2 runs to the back unless there is 2 runs from the alt...
i had planned on doing the same thing with spv70's in the spair tire well... i was going to use a Knukonceptz konfused distro
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
That your engine?
Not mine, but mine looks exactly the same, I got the same BBK tb.
Thanks for the help.
SMD Super Seller
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 1524 Guests (See full list)
