need help before i go insaine
hey lads .
im scott from ontario canada .
and im a big fan of all you guys . i watch steve's vids on you tube all the time .
now ,
im use to 10 inch subs . i had 5 of them
but building thoes boxes wernt to hard .
but iv upgraded to a
cerwin vega stroker and this sucker was a nice penny to buy .
amp i use with this is a kaption audio d1000.1 mono block . that puts out a 1000 rms at one ohm
but anyways . on with the story .
i build some boxes and i cant seem to get it to sound like it should .
like it sounds like its sick or something . so i sent it back and they sent me a new one . put it into the box
samething . and that box was built to there specs . 2.96 cf
so i made a another box at 4 cf . im getting it to sound a lil better . but still sounds stupid .=(bad) lol
and so i made another box . ( this buying , 1 inch mdf is getting stupid . alot of money waisted so far )
so i bit the bullet . and bought 2 more sheets and built another box . that is about 6.3 cf , to try it out = banpass (yes i know )
they suck in my opinion . i like the sub to sit on the box not hidden inside . . and hitting the hatch or roof
but i do have the long rectangle deep port . but that port was in all my boxes .
now it sounds like i said not to to bad . but theres something missing . ( ow right the good sound ) lol hahah
so could you great guys/gurls
of smd help me out . cerwin vega specs are not for a huge space like i got . i drive a 98 dodge caravan . with the back seat out . so i have lots of room to play with
put it this way . my other 2 12 inch subs hit the same . as my cerwin vega stroker .. and thoes 12 inch are cheap walmart specials . i got to hold me
over till i got a new toy . (cerwin vega stroker) but its sad when walmarts subs that are 45 bucks beats my 2000.00 sub. wich i cryed since i cant get it to sound good .
i went to a local dealer . and they said they wernt into custome building boxes so they had no idea (they said they have them manufactured at the dealer) ( example = from kicker or something)
please lads . all the help would be great .
thanks in advance ..
scotty......
That is a :peepwall: of text brah. Not really enough info though if you ask me.
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
You could ask someone to design a box for you tuned to whatever Hz. Let everyone know what your build consist of. Is your electrical done right? How are settings set on your amp? What sub wire and power wire size are you using? How are you getting your measurements to do your own box?
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
sorry
heres some info you needed .
amp wire + is 0 aug
amp wire - is 0 aug
did the 3 upgrade to it .
0 aug the alt , moter 0 aug ground, and - battery 0 aug
speaker wire is a 10 aug
and its a duel voice coil sub.
power cap is 2000 ferrett
and running 2 batteries , both are deep cycle .
amp gain is at 3/4
freg responce is about a lil touch over half
head unit setting at 0 bass .
now the box cf i was doing it like this .
leanth * width * hight - thinkness of mdf divide by 1728
The12volt.com has calculators for port sizes maybe try to type your box info in and see if your port size is accurate?
My First Build on SMD (Blow Through)
2004 Ford F-350 SD Lariat
Pioneer 3200BT DVD Deck
Infinity Reference Components not powered
Bully Dog Gauge Cluster Pyro, Turbo, Trans
SF3 SCT Tuner W/Customs
If you can't Join em' Crush em'
  • Who's Online   0 Members, 0 Anonymous, 2269 Guests (See full list)
