Speaker amp cuts out at high volumes NEED HELP
So I just installed my 4 channel amp, and it works great on low volumes but past 20 it cuts out....the bass works fine all the way up to 35, but the mids/highs amp won't play past 20, it cuts in and out at parts randomly and just won't play...what's wrong with it?
Its all wired corectly, the gains are way down, the Bass boost is off, and the HP is set to 120 and the amp is set in HP mode.
whats wrong with it?
F/s: 2 custom made boxes, for 1 12" and 2 12" hit me up I'll let em go cheap
If the sub amp works, I doubt it's voltage drop. Still check though. Check your grounds too
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Grounds are perfect, everything it looking good....
Could it be that I have 4 gauge then a fuse block, then 8 gauge?? idk
and the ground is (2) 4 gauges, into a dist block, which from there goes out a 4 gauge than a 8 gauge....could that be the problem (although the sub amp is conected the same way?)
It could be the 8 gauge. How much power is the amp pushing?
LMFAO so true
:blush:
1. what ohm load are u running your 4ch at?
2. if the 4ch takes 8guage then run 4gugage grounds then drop it to 8guage at amp if u can
3. what kinda sub amp do u have? does it cut out when the subs are cut off?
and try and check your rcas, might have a loose connection somewhere, and check wires comeing from amp, might be loose
The amp is very small, rated at 250 watts max and 40x4 RMS, alpine MRP250
1.idk, I have it hooked up to my components and the cross overs have both tweet and mid inputs, so i have ch1 going to tweet RIGHT, and ch2 going to mid RIGHT, and ch3 going to tweet LEFT, and ch4 going to mid LEFT. I heard it's a 2 way active setup, and should work like that.
2. Thats what I did, I have (2) 4 gauges going into a dist. block, than from there (1) 4 gauge to sub amp, and (1) 8 gauge to speaker amp (the one thats giveing me trouble)
3. Sub amp is PDX1000, I've never tryed turning it off to see it it still has that problem I will try it in a min, good suggestion.
4. RCA's are perfect all around
Remote wire secure? Maybe one of your speaker wires are loose behind the speaker and its shorting the amp? Have you checked those?
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
  • Who's Online   1 Member, 0 Anonymous, 1618 Guests (See full list)
