AMP/Subs setup suggestion (upgrades)
hey guys,
I'm currently running two JBL 1214D's on a clarion DPX11551 (1550RMS at 2ohm). I would like to upgrade to two JBL W12GTI MK2's in a month or two if I can come up with some cash. I can wire them in parallel at 1.5 ohms, but the amp is 2 or 4 ohm stable and not 1 ohm stable. it would be for daily use. I don't want to shell out the cash for another amp if I don't have to. I don't think running them in series/parallel at a 6 ohm load will give enough power with this amp. If it isn't a good idea to run them at 1.5 ohms, I will wait longer and buy another DPX11551 and stack them, running each sub at 3 ohms. Any suggestions on this would be greatly appreciated. (money saving suggestions FTW, thx!)
2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp)
SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
Bump 4 quick answer
ive never played with that amp but i would imagine it will be ok. its getting to the gray area but as long as it doesnt go into protect right away, box rise should help you out.
Cool. Will it shorten the life of my amp? Any assumptions of how nuch power the amp is capable at 1.5 ohms? And what exactly is box rise? Thanks again for the help guys.
pressure in the box will raise the impedance when the subs are playing. the 1.5ohms you are measuring is dc resistance. impedance is ac "resistance". your amp puts out ac current so its more relevant. 2x-3x rise is very common so you could easily be seeing 4ohms so there is no real way to say how much power you will get. unless you buy an AC clamp meter and a DMM and measure it yourself.
lower ohm loads will cause the amp to work harder, pushing more current. current = heat, and heat is very bad for electronics. i would recommend putting the amp in an amp rack with fans to cool it down. they dont have to be very powerful fans. just a little air across the heat sink will do a lot.
chill. thanks for the info, skittles. You know your stuff. What I will most likely do is buy the 2 subs first, then either run them at 1.5ohms for a bit and buy a second amp, or just buy a second amp right away, same one I have now (dpx11551), and stack the amps. This will give me much more power anyways and the amps should last longer. But first I have to make lots of money. (don't we all...)
amps are less efficient when you strap them. its best to run each amp to one sub then gain match the amps.
My friend "had" that amp until he broke it when he ramped a bridge...
Don't ask about that LOL!
Anyways I asked around on here about the amp and people said it's a nice amp and it will put out it's rated power.
thanks for the response guys! I love this amp so far, my concern is if it will last long at 1.5 ohms ( i think it should) or if I should just invest in a second one of the same model, and have each of the JBL GTI's on each amp set at 3ohms. In both situations they should get full RMS power, no? but i drive often and I would like the amp to last. a second DPX11551 would set me back about $400, and I'd rather use that for a portable o-scope lool.
  • Who's Online   0 Members, 0 Anonymous, 1599 Guests (See full list)
