I have 2 RF t2500.1bds... I'm confused as hell about this problem.... I am using master slave on my amp and one amp is 1.5v higher than the other... Its connected correctly, and that's exactly how meade is using his. Any opinions? What to check do change?
1 Crossfire XS v2 15"
2 Deka group31a's
1 XS Power D3400 (under hood)
1 Addictive Audio 500.1 :D
1 Rockford 3sixty.2
4 Crescendo pwx 6.5s
2 Pyle Pro Super tweets
1 Crescendo 1000c4
Kenwood excelon x494 Head unit
Big Three upgrade
All 0 gauge of course
1 4.56c^ft box @28hz
(New Best official db score= 151.2 @ 36hz)
Are you stacking your connectors on the battery posts? That'll do it...
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
What are you talking about the input voltage or output voltage on the speaker terminals?
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
no it would only be a drop of at max like .2 volts from slaving it... and should i just like buss bar all 4 batts rather than having wires between them all? maybe that would make them all fire evenly over the amps? I mean thats my only idea really...
Edit: Talking about the input voltage at the + - inputs....
Edited by REaudioBuff
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
Well when you keep stacking the connectors it gain LOTS of resistance. Buss bars imo are more clean and organized and won't suffer all the resistance from the way your doing it now.
2007 Chevy HHR LT
UNDER CONSTRUCTION
do you think that will fix alot? or do you think i might also have a fuse blown or something of that nature? I mean this weekend im going to take my subs and box out and re wire the batts re fuse it all and hope that solves it. But im just looking for ideas as to what else could help.
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
how r u testing voltage between the 2 amps?
dmm plus the led on the amp itself shows it.. plus its not as loud... something is wrong its like a batt is bad or something idn...
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
Try re wiring. Like make it so amp 1's power wire is where amp 2's power wire would be, and vice versa see if the resistance theory holds up. If you notice the slave amp is still at 1.5v less than the master.. Then idk? Jus throwin suggestions out
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
  • Who's Online   0 Members, 0 Anonymous, 3465 Guests (See full list)
