ok fellow users my noobish question is when building enclosures do yall prefer using screws or staples? and for what reasons?
Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
anyone?
i use screws glue and air nails screws for the double baffle. glue for the corners and putting pieces together and the nailes to hold together but also resin the inside of the box if y use nailes they cant hold for all that pressure deppended on set up
do you think that for a 1krms setup for two 12's, staples would be fine?
the screws and brad nails just hold the edges tight together while the glue dries. once its dry, the fasteners dont do much. if you use staples then you need to add pressure before shooting them in, they wont create enough. so you either clamp one side at a time then use the staples or you stand on the box, this obviously only works on a couple places.
screws will clamp the 2 pieces together much better and form a stronger bond.
allrighty then thx for the help skittles&teejay screws are the way to go, do you all know any good screw countersink sets for cheap? i wanted to check out sears but any other options?
Edited by pheint_1
I use to use screws but its a huge waste of time... brad nails, glue, and clamps ftw... and double wood where you need to.... I've built alot of enclosures and have had 0 failures... Some pretty big ones too, such as 2 15s 3kwrms+ 8+ cuft (10.5 external) and have 0 flex or blowout problems.
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
I use to use screws but its a huge waste of time unless, brad nails, glue, and clamps ftw... and double wood where you need to.... I've built alot of enclosures and have had 0 failures... Some pretty big ones too, such as 2 15s 3kwrms+ 8+ cuft (10.5 external) and have 0 flex or blowout problems.
thats how i build them now too. as long as you have enough clamps, your good.
lol so brad nails arnt that bad a choice?, i already got the brad nails/gun and titebond where could i get some cheap clamps, ive heard that harbor freight is an easy choice for good&cheap?
Get some clamps as long as they work they work doesn't matter the cost... When I glue my wood I make sure to use a paint brush and smear it all the way across and then clamp it down TIGHT and wipe away the excess then I put a bradnail every 1.5-4"
My YouTube Videos
