Installing some new batts.. NEED HELP!!
Alright i have 2 hc2400s and 2 hc16v batts that im putting in the back of my car. What i wanna know is what the best way to wire them up is... Take the power coming from up front put it to one batt then just series that or what? Im running 2 t2500.1bds off them so i want all batts to be charging each amp. I will put a t1000.4 on them also but thats about 2 months away. Help me out guys i just wanna know what way would be best for power.
1 Crossfire XS v2 15"
2 Deka group31a's
1 XS Power D3400 (under hood)
1 Addictive Audio 500.1 :D
1 Rockford 3sixty.2
4 Crescendo pwx 6.5s
2 Pyle Pro Super tweets
1 Crescendo 1000c4
Kenwood excelon x494 Head unit
Big Three upgrade
All 0 gauge of course
1 4.56c^ft box @28hz
(New Best official db score= 151.2 @ 36hz)
Your running 16v batts on a stock alt? Not sure that would even work. Just sell them and get another 2400 or 2.
im using the 14v output sides of them... They are just bigger than the hc1400 as far as amps go so i am using them. I just need to know how to wire the batts just like you would wire any other normal 4 batts so that it is a big bank.
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
wire them in parallel. You can ground the front one to the chassis, or run a wire all the way to the back. Same goes with the rear. You can ground them to the frame, or eachother. But, what you do to one, do to the rest.
Edited by Alex K
2006 Nissan Z Track.
My Feedback Thread
i used to think a band pass was something you were around your neck or something.
ok so i have a ground at the back of my car now should i use that as the ground for all of the batts just like it is currently being used?
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
if its sanded and bare metal go for it. but where you ground 1, ground them all. dont ground 1 on the left, one on the right, one to another bat, one to the roof, etc. All 1 spot, including any amps that are around.
Edited by Alex K
My Feedback Thread
yea its sanded down and bare metal. thanks for the help bro i needed to see that pic that def helps a bunch.
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
  • Who's Online   0 Members, 0 Anonymous, 1350 Guests (See full list)
