REaudioBuff Posted August 12, 2010 Report Share Posted August 12, 2010 Alright i have 2 hc2400s and 2 hc16v batts that im putting in the back of my car. What i wanna know is what the best way to wire them up is... Take the power coming from up front put it to one batt then just series that or what? Im running 2 t2500.1bds off them so i want all batts to be charging each amp. I will put a t1000.4 on them also but thats about 2 months away. Help me out guys i just wanna know what way would be best for power. Quote 1 Crossfire XS v2 15" 2 Deka group31a's 1 XS Power D3400 (under hood) 1 Addictive Audio 500.1 1 Rockford 3sixty.2 4 Crescendo pwx 6.5s 2 Pyle Pro Super tweets 1 Crescendo 1000c4 Kenwood excelon x494 Head unit Big Three upgrade All 0 gauge of course 1 4.56c^ft box @28hz (New Best official db score= 151.2 @ 36hz) Link to comment Share on other sites More sharing options...
OBI Posted August 12, 2010 Report Share Posted August 12, 2010 Your running 16v batts on a stock alt? Not sure that would even work. Just sell them and get another 2400 or 2. Quote Link to comment Share on other sites More sharing options...
REaudioBuff Posted August 12, 2010 Author Report Share Posted August 12, 2010 Your running 16v batts on a stock alt? Not sure that would even work. Just sell them and get another 2400 or 2. im using the 14v output sides of them... They are just bigger than the hc1400 as far as amps go so i am using them. I just need to know how to wire the batts just like you would wire any other normal 4 batts so that it is a big bank. Quote 1 Crossfire XS v2 15" 2 Deka group31a's 1 XS Power D3400 (under hood) 1 Addictive Audio 500.1 1 Rockford 3sixty.2 4 Crescendo pwx 6.5s 2 Pyle Pro Super tweets 1 Crescendo 1000c4 Kenwood excelon x494 Head unit Big Three upgrade All 0 gauge of course 1 4.56c^ft box @28hz (New Best official db score= 151.2 @ 36hz) Link to comment Share on other sites More sharing options...
Alex K Posted August 12, 2010 Report Share Posted August 12, 2010 (edited) wire them in parallel. You can ground the front one to the chassis, or run a wire all the way to the back. Same goes with the rear. You can ground them to the frame, or eachother. But, what you do to one, do to the rest. Edited August 12, 2010 by Alex K Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
REaudioBuff Posted August 12, 2010 Author Report Share Posted August 12, 2010 ok so i have a ground at the back of my car now should i use that as the ground for all of the batts just like it is currently being used? Quote 1 Crossfire XS v2 15" 2 Deka group31a's 1 XS Power D3400 (under hood) 1 Addictive Audio 500.1 1 Rockford 3sixty.2 4 Crescendo pwx 6.5s 2 Pyle Pro Super tweets 1 Crescendo 1000c4 Kenwood excelon x494 Head unit Big Three upgrade All 0 gauge of course 1 4.56c^ft box @28hz (New Best official db score= 151.2 @ 36hz) Link to comment Share on other sites More sharing options...
Alex K Posted August 12, 2010 Report Share Posted August 12, 2010 (edited) if its sanded and bare metal go for it. but where you ground 1, ground them all. dont ground 1 on the left, one on the right, one to another bat, one to the roof, etc. All 1 spot, including any amps that are around. Edited August 12, 2010 by Alex K Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
REaudioBuff Posted August 12, 2010 Author Report Share Posted August 12, 2010 yea its sanded down and bare metal. thanks for the help bro i needed to see that pic that def helps a bunch. Quote 1 Crossfire XS v2 15" 2 Deka group31a's 1 XS Power D3400 (under hood) 1 Addictive Audio 500.1 1 Rockford 3sixty.2 4 Crescendo pwx 6.5s 2 Pyle Pro Super tweets 1 Crescendo 1000c4 Kenwood excelon x494 Head unit Big Three upgrade All 0 gauge of course 1 4.56c^ft box @28hz (New Best official db score= 151.2 @ 36hz) Link to comment Share on other sites More sharing options...
Alex K Posted August 12, 2010 Report Share Posted August 12, 2010 youre welcome bro. Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
soundzright Posted August 12, 2010 Report Share Posted August 12, 2010 You can not just use the 12 volt post on a 16 volt battery. It has to be charged on the 16v post and it wont charge on 14 volts. Quote Link to comment Share on other sites More sharing options...
dugee81 Posted August 12, 2010 Report Share Posted August 12, 2010 Yeah to run a 16v battery, wouldnt you want to charge it at 17-18v? Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
