Hey guys
I've been lurking and reading about systems for a while. bit the bullet the other day and bought a hdc315 and a aq2200d to go with it.. kinetik 1800 installed in trunk.. 0 gauge wire ran.. the voltage to the amp never dips below 12.8v while bumping
ok, now heres my question.. i've been using the remote bass knob and clipping light that comes with the 2200d the past couple days and i'm stumped as to why the amp clips already at around 1000rms.
I set the HU(clarion 785) to 21-22 volume out of 33.
bass boost at 0
lpf around 100
ssf around 35
I then play a test tone of 40-45hz at around 900-1000 watts before the clipping light blinks.. even for some songs.
Why would this amp clip @ 1000rms? am i doing something wrong? i eventually want to feed this sub around 1500rms..
LPF around 70-8O should be fine. Won't affect clipping. How do you know you are around 1k watts? Using DMM? That's not really a good way to tell the actual output of the amp. If you live in an area with some good shops maybe you can find a place that has an o-scope to set your gains. That's the best way. Also make sure your EQ is flat and not on super bass or something.
Those clipping lights on the knob aren't very accurate from what I've read.
Also, don't listen to Speedball. He doesn't know what he's talking about.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
  • Who's Online   0 Members, 0 Anonymous, 1076 Guests (See full list)
