Stop just throwing nonsense out there.
"Set your LPF to 50 hz that will help." No...not at all. That's pretty low for a LPF and has nothing to do with his clipping.
"Just put your gain at 1/2 and 1/4 bass boost." Umm...why would he do that. May as well just max both and see how it goes.
I guess by what he's written he thinks that putting his gain at 3/4 will make his amp put out 3/4 of 2200 watts. Not true at all. Your gain is there to match your HU's output voltage. If your HU outputs a high voltage through the RCAs your gain will be lower. If your HU has a weak RCA voltage your gain will have to be higher to get the same output.
Now I see what your saying... i believe my HU has 6v pre-outs so my amp at half gain is already probably 1500+ watts? i didn't know that.. lol
It is right. THe gain knob is not a volume knob. If you have a HU that puts out high voltage through the RCA (or are using a line driver) you could have the gain pretty much all the way down and be getting full power from the amp. The gain knob is there for the amp to compensate for different HUs putting out different RCA voltages.
If you just crank the gain trying to make it louder, your sub won't last long.
i believe this has been said twice now before you decided to make it 3x lmao
6v?? damn i've got a hu thats 4v and there are a few that are 5v they just barely came out with these, what brand headunit and amp do you have??
YOu can't really guess at it like that. If your amp has 6v pre outs (which is pretty high) you could have your gain at like 1/8th and be getting full output. The only way to REALLY know is using an o-scope. Not always practical for everyone, though.
Just make sure your EQ is flat or very close. LPF around 70-80 should be fine. No bass boost, or "loud" on the HU. If your HU has a "sub level" that can be all the way up (will make sure your HU puts out higher pre-out voltage).
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
Well, he's already said what HU and amp he has, but you asked anyway.
I said it because he may have missed it because he was still assuming the gain was a wattage knob. Why don't you stop worrying about what I repeated and start reading more so you spout less nonsense advice.
Pioneer DEH-P6000UB
Sundown SAX-50.4
Sundown SAX-1200D
Stock Bose system
Profile AP1000M
Awesome. yea i was wondering when earlier today i turned the sub level on the HU up to +6 (was at 0 before) and then the signal started to clip until i turned it down to like 1/4 gain and it sounded just as loud as it did at 1/2 gain.. haha. i love this sub.. just want it a little louder haha.
  • Who's Online   0 Members, 0 Anonymous, 755 Guests (See full list)
