AA98hoe Posted August 16, 2010 Report Share Posted August 16, 2010 I have two ddm4s putting 7k plus to my 4xl 18s and they are barely moving. i would like to double the power. i know what you all are going to say i will set my gains with a oscope. what is the best 12 to 15 k amp that will do .7 daily TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
speedball1978 Posted August 16, 2010 Report Share Posted August 16, 2010 ouch .7 daily? check out soundstream xxx ampi think they do 16k Link to comment Share on other sites More sharing options...
rival904 Posted August 16, 2010 Report Share Posted August 16, 2010 Get 2 M4a's? 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
Ji553r Posted August 16, 2010 Report Share Posted August 16, 2010 i only know of a few amps that will give that much by themselves..... RF t15k, stetsom 14k or 11k but i heard those do around 9k instead, soundigital, taramp I don't fuck around. I go from zero to I hope you die in less than 2 posts build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/ Link to comment Share on other sites More sharing options...
TeamHT Posted August 16, 2010 Report Share Posted August 16, 2010 are the subs brand new? lol, ive seen subs move on a couple hundred watts. Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
AA98hoe Posted August 16, 2010 Author Report Share Posted August 16, 2010 two are new two are a month old. never heard of taramp. and you want to buy the m4s so i can get the m4as. TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
TeamHT Posted August 16, 2010 Report Share Posted August 16, 2010 two are new to are a month old. never heard of taramp. and you wnt to buy yhe m4s so i can get the m4as. and none are moving? Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
AA98hoe Posted August 16, 2010 Author Report Share Posted August 16, 2010 what about cactus or ab? TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
AA98hoe Posted August 16, 2010 Author Report Share Posted August 16, 2010 lol no they are moving,its the loudest its ever been. i just think theres alot more left in them. i had to get my rear side window cut out and resealed cause the bass blew it out and it was making a ugly buzzing sound(when it flexed out a inch or so lol ). TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
AA98hoe Posted August 17, 2010 Author Report Share Posted August 17, 2010 so no other suggestions? was thinking about stetsom and soundigital but i heard they send a weird freq out and fry tinsel leads. and they hate clipping. anyone know this from experience? TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
