Rickdod3 Posted August 24, 2010 Report Posted August 24, 2010 Hey everyone im currently in the process of designing a box for 2 18" XL's and I was wondering if someone could help me out... Its going to be a "wall" in my jeep, not a permanent wall but its going to have trim panels around it to give it the look of a wall...anywho I did the dimensions on it today and it came out to... 40" Wide, 35" Tall and 29" Deep...that right there comes out to 17.8 Cubic Feet...Im planning on doing a port on the box and I want it tuned around 33-35hz... Im pretty much at a stand still right now and I figured id ask some people that know what the DC subs need. So yeah Id really appreciate any help I could get. Thanks again, Rick Quote Audio Technix Online Customer Service Specialist [email protected]
Rickdod3 Posted August 24, 2010 Author Report Posted August 24, 2010 Bump* Also I forgot to say that the 17.8 is what I have to work with...that is the max size I can do the box and still have it the way I want it to fit...If im not mistaken the box should be like 12-13 cubic feet for 2 18" XL's. Quote Audio Technix Online Customer Service Specialist [email protected]
matt402 Posted August 24, 2010 Report Posted August 24, 2010 i think it would be a good daily box after port & sub displacement. Quote
Rickdod3 Posted August 24, 2010 Author Report Posted August 24, 2010 Yeah im hoping so, my goal is high 140's maybe 150 with this set up, I still need to figure out the port size and stuff prolly tonight, ill prolly post my dimensions for everything on here tonight...hopefully someone tells me yay or nay lol Quote Audio Technix Online Customer Service Specialist [email protected]
AA98hoe Posted August 24, 2010 Report Posted August 24, 2010 What kind of power u going to use? and hows your electrical? I had my xls in 13 cubes with 16 sqin a cube tuned to 32hz running off of 7000w. sounded great i would go with bigger port since you have the space and tune to low 30s. should be devastating with alot of power Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Rickdod3 Posted August 24, 2010 Author Report Posted August 24, 2010 Right now the power is the only issue...Im having trouble getting ahold of iraggi for my alt...and Ive tried mechman and he doesnt have one to fit my jeep...dc power doesnt ether... but my plan is to have a 300amp alt, with prolly 2 kinetik 1800's in the back and a 2000 in the front, with all 1/0 gauge... I havent decided on a amp(s) yet...I also thought about doing just level 4's instead of the xl's cause I dont know how much my alternator is going to be and im on a tight budget...but if I do end up just getting the level 4's im thinking ether a Powerbass 5000 or something close to it, i need to research some amps...any suggestions? Quote Audio Technix Online Customer Service Specialist [email protected]
memphisBred Posted August 24, 2010 Report Posted August 24, 2010 I'm having James design me a wall for 2 XL 18's off of 2 AQ 2200d's. And also the space I am using is 41" wide, 34" tall, and 28" deep. lol. That's almost the same as yours. That, too, is the space available. I'm hoping to keep it around 12-12.5 cubes at ~35 Hz. Quote SMD Super Seller/Buyer Audison----Hertz----Rainbow
Rickdod3 Posted August 24, 2010 Author Report Posted August 24, 2010 Hell ya lol thats awesome, how do you like those AQ amps? I looked those up them seem pretty good, and they arent super expensive ether Quote Audio Technix Online Customer Service Specialist [email protected]
memphisBred Posted August 24, 2010 Report Posted August 24, 2010 (edited) It's perfect for daily beating. Have it wired to 1 ohm and it was really making the XL sing, and move too. Doesn't get warm at all, unless it sits in the 110 degree weather. It's a great match IMO. After I get everything done I will likely get the XL's reconed so I can wire below 1 ohm. Also it doesn't help that the AQ is seeing about .9 volts from my awesome Jensen H/U(Alpine 9886 was stolen three months ago). Piece of crap clips before 1 volt. New H/U and Audio Control Overdrive should make the AQ happier. Edited August 24, 2010 by memphisBred Quote SMD Super Seller/Buyer Audison----Hertz----Rainbow
Rickdod3 Posted August 24, 2010 Author Report Posted August 24, 2010 Haha yeah, one of my biggest concerns about finding amps right now is because I cant find a alt for my jeep...stock is like 120 amps I think and a 250 amp alt from dc is supperrrrrr expensive...so idk what im going to do yet, but those amps seem like a pretty awesome product Quote Audio Technix Online Customer Service Specialist [email protected]
