dog24fret Posted August 25, 2010 Report Posted August 25, 2010 i am installing comp. set in a 97 E ford van and was curious if the stock location with a fiberglass enclosure will work almost as good as speaker pods the first place i wanted to put them has the window motor there and the pod i was going to make will leave no leg room any help will be appreciated Cowboy Escort GrAnny ThUmper The Burp
Bumpin the TWP Posted August 25, 2010 Report Posted August 25, 2010 The stock spots should work fine 2x Sundown Audio SA-15's nuff said for my little old car 1999 Plymouth Breeze Build Log
Alex K Posted August 25, 2010 Report Posted August 25, 2010 I had to pretend i was in 3rd grade for a second to understand that... But unless you're running a shitton of bass, the stock spots will be fine. If you're going to take the time and glass an enclousure, at least make it worth your time and add more speakers. Not just one. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
skittlesRgood Posted August 25, 2010 Report Posted August 25, 2010 you want the speakers as far forward as possible. so as far forward as you can in those doors will be great. usually the stock spot is pretty far so it'll be ok. do your best to aim the speaker directly at opposite person's head, passenger speaker pointed at driver, etc. you dont need a ton of speakers for SQ but you do want to put them in an enclosure. just make sure its 100% sealed. a fairly large pod will help a lot with midbass. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
dog24fret Posted August 25, 2010 Author Report Posted August 25, 2010 you want the speakers as far forward as possible. so as far forward as you can in those doors will be great. usually the stock spot is pretty far so it'll be ok. do your best to aim the speaker directly at opposite person's head, passenger speaker pointed at driver, etc. you dont need a ton of speakers for SQ but you do want to put them in an enclosure. just make sure its 100% sealed. a fairly large pod will help a lot with midbass. Cowboy Escort GrAnny ThUmper The Burp
dog24fret Posted August 25, 2010 Author Report Posted August 25, 2010 thank you for that the pod will be fair size for the 6.5 component set and degree angels figured already too just got to build now so i can have the system running again will be running 2000 to subs 120 to rear fill 100 for center and front that should balance out ok old school learning new Cowboy Escort GrAnny ThUmper The Burp
