Bigger wire would not fix that voltage.
+ a batt for the back? i plan to run, 1 run of 0g to the back batt, then 1 4g run to the 4ch then 1 0g run to the sub amp,
i just want to atleast stablize it to an extent
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
put your batt on to charge.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Guest DC Power Kyle
We do have a way to bypass the PCM regulator and get a constant 15 Volts with no charging light with our state of the art 270xp. However we can only bypass it if you run one of our alternators. Let me know!
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
