ive been having problems with keeping the volts up to my amp. i just installed a 220amp excessive amperage alt to fix the problem. i tried the system and im still having the same problem. the volts at the battery stay consistant at 14.4 no matter how loud the system is, but the amp is ranging from 13.6 - 11.7. what could be causing this problem? possibly a bad ground or something is wrong with the amp itself?
all imput will be appreciated. thanks
heres some questions that will help us figure out what could be wrong with it
what amp is it
what guage wire u running?
what do u have it hooked to sub wise and ohm load?
and what kinda other electrical do u have other than the alt?
Edited by tacomabanga1986
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
what amp is it
rockford fosgate t2000.1bd
4 gauge as of right now
its wired to 1 ohm
i have the big 3 done in 0 gauge and a optima yellow top.
oh, and did u set the gain by ear or with a digital multi meter?
could be clipping makeing it fluxuate so much
or could be ground problem cause the front battery voltage should move with it also
is your grounds sanded down to bare metal and seccurly tightened?
its wired to 1 ohm
with 4guage i would wire the sub(s) to the highest ohm load that u can till u get some 0guage, that might fix ur voltage problem :)
with rockford amps they need power to make power, with that big of an amp, u dont want to see ur volts drop down to 11.xx, try to keep it to no lower than 12v if u can help it with car running
You're probably pulling close to 300A through a piece of wire that's made to take 100A.
I bet that's where a lot of your voltage drop is coming from.
10.x volts fo' life!
i bet getting rid of that 4gauge and using 0gauge will help.
X2 I also have a t20001bd and it draws a lot of current. It comes with a 250 amp. fuse so you know it needs a heavy wire.
you really need some 0 ga wire and check your grounds on both ends (at amp and body or frame to engine) this i have seen happen before and the ground strap on the motor was really corroded and it was causing that problem. we replace d the ground to from the motor to the body/batter with some 0ga and it worked great
Build in progress
Alpine CDEHD-138BT
Alpine SPX-17PRO 2x
Alpine SWS-15d2 2x
Alpine PDX-V9 2x
Alpine PDX-M12
Stinger SPC5050
Stinger 1/0ga and 4ga
Audioquest interconnects and Speaker wire
Dynomat 10455 mega bulk pak
Dynomat 1/8 and 1/4 liner
All that in a Reg cab truck and it wont be a blow though
  • Who's Online   0 Members, 0 Anonymous, 552 Guests (See full list)
