getonerd Posted October 3, 2011 Author Report Posted October 3, 2011 well im goin to do any ipad replacement or addon but i havent made my mine yet on what to do i have the following an knock off ipad dock that i took apart ipad connecter to RCA with USB ipad usb cig lighter that im goin to mod or get a female to 2 wires im goin to used my 360.2 aux output 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
reharrac Posted October 3, 2011 Report Posted October 3, 2011 what rta are you using? and what o-scope are you using?
getonerd Posted October 4, 2011 Author Report Posted October 4, 2011 i stuck out on look for that dash part then my cable went out so i was bored so i painted some trim was goin to the bottom grill but not finding that part was pissing me off and i dont want to used the one i h 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
getonerd Posted October 10, 2011 Author Report Posted October 10, 2011 well as my son takes a nap im goin to start glassing my pad im goin to do an two piece top & bottom its all foil and taped up ready to glassed 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
soundcheck11 Posted October 10, 2011 Report Posted October 10, 2011 Everything is coming along quite nicely. My only thoughts would be, like everyone else has said, to take a bit of time and really sand down them door builds. throw a few coasts on there until it gets nice and smooth, then cover it or paint it. Paint them red like everything else you got going on in the car. The other thing is....your "a" pillar volt gauge...that is direct from alt, correct? How did you wire it? Normally you can wire them straight to the ignition wire and ground and that will give you straight alt voltage as well. that is if thats what you did, if not do it that way. And, i would also put your stinger gauge somewhere else that is easily visible if you happen to be booming down the road, dont want to be looking up and not have some better eye sight on the road. If you can put it somewhere up at about steering wheel hieght it will look abut better. Good job for your first time thou. Everything is a learning experiance
getonerd Posted October 10, 2011 Author Report Posted October 10, 2011 well the doors might be getting a redo or upgrade i thinking of doing 3 set 6.5 comps or putting my stock door back in and mount the 8 in the stock location and fab in the 6.5 to rear door the volt meter is wired to the battery as my stinger was i did a big three w\ 0ga 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
getonerd Posted October 11, 2011 Author Report Posted October 11, 2011 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
getonerd Posted October 11, 2011 Author Report Posted October 11, 2011 well ran into a snag, i got hell of noise coming out of the aux of the 360.2 im guessing cheap RCA and then i broke my dock connector so when i get a chance im goin to get an new one 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
getlocivic Posted October 11, 2011 Report Posted October 11, 2011 well i think the big 3 was an big fail i only gained .7 volts maybe i shouldn't have fused it what ddi you expect to see going from what high 13 volts to 15 volts lol... no.. generally at most u get 1 volt more.. and its always smarter to fuse all wires my wife has a 05 g6 gt i have her stinger volt meter mounted in the little cubby hole in front of the shifter... looks ALOT better than hwere u have it.... super easy to install it there also... no cutting required and the trim panels r easy to remove also bc they r velcrod on
getlocivic Posted October 11, 2011 Report Posted October 11, 2011 also dbelectrical.com has a 250 amp alternator for the g6 with the 3.5 for 250 bux.. they will powdercoat it any color u want for 50 more.. my wifes been running the 250 amp alt with a single xs 3400 poweering a audiopipe 1800 and 4 channel for over a year now and it never dips below 13.5 volt even with ac full blast at idle
