Best way to clean engine... Engine is now clean!
I use simple green cover my alt...thats all...
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
i use purple power and a power washer
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Alrite so I had one more quick question. I'm about to start washing but do I have to cover the connections like these.
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
it probably wouldnt hurt to wrap a piece of plasic around those connectors... i personally have never covered anything and havent had a problem... just make sure you spray all the excess water out with an hair hose...
3 Kinetik Hc2000's
Dual 200amp alts.
Well I basically listened to all the people that replied. I covered all the electrical. Sprayed everything with Engine Bright, scrubed it with a brush and let it sit for like 10-15 min. Then I sprayed it all down with a pressure washer. Once it's almost dry I let the engine idle for a bit to finish drying
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1456 Guests (See full list)
