jg23 Posted August 28, 2010 Author Report Posted August 28, 2010 Alrite. For sure once I'm done I'll get another pic Quote 2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0 Build Log UBL My YouTube channel
z71kris Posted August 29, 2010 Report Posted August 29, 2010 I use simple green cover my alt...thats all... Quote 03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
Rogers Posted August 29, 2010 Report Posted August 29, 2010 i use purple power and a power washer Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
jg23 Posted August 29, 2010 Author Report Posted August 29, 2010 Alrite so I had one more quick question. I'm about to start washing but do I have to cover the connections like these. Quote 2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0 Build Log UBL My YouTube channel
Rogers Posted August 29, 2010 Report Posted August 29, 2010 it probably wouldnt hurt to wrap a piece of plasic around those connectors... i personally have never covered anything and havent had a problem... just make sure you spray all the excess water out with an hair hose... Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
jg23 Posted August 29, 2010 Author Report Posted August 29, 2010 Engine is clean now! Pic is at the top Quote 2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0 Build Log UBL My YouTube channel
Rainman215 Posted August 30, 2010 Report Posted August 30, 2010 You forgot to tell us your method Quote My 02 Accord Wall Build 2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500 Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
jg23 Posted August 30, 2010 Author Report Posted August 30, 2010 Well I basically listened to all the people that replied. I covered all the electrical. Sprayed everything with Engine Bright, scrubed it with a brush and let it sit for like 10-15 min. Then I sprayed it all down with a pressure washer. Once it's almost dry I let the engine idle for a bit to finish drying Quote 2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0 Build Log UBL My YouTube channel
