Swaggasaur Posted August 29, 2010 Report Posted August 29, 2010 i have an 86 monte carlo with stock electrical, and might have to upgrade my electrical for a hifonics BRZ 2100.d. its supposed be able to put out 2100 watts rms at 1 ohm. there new line is CEA certified. anyway, whats better to use? optima depp cycle battery or hook up another regualr battery? dont know if this does anything, but the battery is has side post terminals. BHE Wall Build TEAM DC Audio TEAM XS POWER1986 Monte Carlo KMC Nova's 20"4 DC XL's W/ PSI Recones2 DC 5k'sPioneer PRS 8010 Audio Technix 6 XS Power D3100's 1 XS Power D3400 Mechman 220a Alternator
Toady Posted August 29, 2010 Report Posted August 29, 2010 i have an 86 monte carlo with stock electrical, and might have to upgrade my electrical for a hifonics BRZ 2100.d. its supposed be able to put out 2100 watts rms at 1 ohm. there new line is CEA certified. anyway, whats better to use? optima depp cycle battery or hook up another regualr battery? dont know if this does anything, but the battery is has side post terminals. That is a good sized amp so it will take some power. I would get the Optima yellowtop g31 with top and side post terminals. Do the big 3 upgrade for sure and you should be fine. If you are still experiencing a voltage drop that dips pretty low go ahead and put another one in the trunk but make sure to fuse both ends of the power wire that runs to the battery just to be on the safe side hope all works out bro
STEvil Posted August 29, 2010 Report Posted August 29, 2010 Should be no issue with voltage drop with a pair of optima's. Gonna run out of power eventually though if your alt cant charge your batts. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Swaggasaur Posted August 29, 2010 Author Report Posted August 29, 2010 That is a good sized amp so it will take some power. I would get the Optima yellowtop g31 with top and side post terminals. Do the big 3 upgrade for sure and you should be fine. If you are still experiencing a voltage drop that dips pretty low go ahead and put another one in the trunk but make sure to fuse both ends of the power wire that runs to the battery just to be on the safe side hope all works out bro ive seen video on how to do the big 3, but its all been with top post terminals. but the side post terminals are pretty much the dumbest idea ever created, how would i do the big 3 with the sides? BHE Wall Build TEAM DC Audio TEAM XS POWER1986 Monte Carlo KMC Nova's 20"4 DC XL's W/ PSI Recones2 DC 5k'sPioneer PRS 8010 Audio Technix 6 XS Power D3100's 1 XS Power D3400 Mechman 220a Alternator
jay_dallas_bass Posted August 29, 2010 Report Posted August 29, 2010 ive seen video on how to do the big 3, but its all been with top post terminals. but the side post terminals are pretty much the dumbest idea ever created, how would i do the big 3 with the sides? edit to answer your question just trim some of the plastic or get a slightly longer bolt for your positive terminal then slide a protective cap over it( Electrical tap is good too) Actually side post terminals are less likely to corrode than the top post. Case in point how many times have you seen someone cleaning side post terminals in comparison to top post terminals? Just saying bro. My Build Log- The Celebrity
Watch the bass Posted August 29, 2010 Report Posted August 29, 2010 i have an 86 monte carlo with stock electrical, and might have to upgrade my electrical for a hifonics BRZ 2100.d. its supposed be able to put out 2100 watts rms at 1 ohm. there new line is CEA certified. anyway, whats better to use? optima depp cycle battery or hook up another regualr battery? dont know if this does anything, but the battery is has side post terminals. If you havent the Optima in your closet, i would have a look at XS or Stinger. Read that they have another kind of function who is much more positiv to put out power for Systems. "in the abundance of water, the fool is thirsty" Bob Marley
Toady Posted August 29, 2010 Report Posted August 29, 2010 To do Big Three Upgrade with side post terminals here is the easiest way possible. Get you an optima Yellowtop G31 Battery with side post and top post terminals. Hook all stock wiring to side posts, then get you top post adapters and run a 1/0 charge wire, 1/0 engine ground, and 1/0 chassis ground. If you need any help or pictures let me know
