lookin good so far ma dudee
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Plexi routered and ready for a 45 degree angle
flush trim router the plexi after being stuck to the template
cut off the excess plexi material with a jig saw so it does melt while routering
Template stuck to plexi....step on it for best adhesion
Tape the back of the panel before the alumn foil to keep the foil from falling out
ca glue the outside ring to the bottom insert ring check fit
outer ring drawn out
45 degree bezel on plexi with the router
Test fit insert after marglass coat
mix up the mar glass and spread away
foil the inside to keep marglass from falling in
glue the foil to get a basic shape...waaaay faster then fiberglass and fleece
plexi Insert wrapped with perforated vinyl and surrounded by smd led lights
PLexi insert lit up and also lighting up the amps ready to do the logo and make a false floor
panel is done test fitted and ready to wrap
skimmed the panel with z-grip bondo
finished with the amp rack all in a days work. Tomorrow 9/2/10 im going to build the false floor build the logo plexi plate send it to get laser etched and try to wrap the wirring up in the car . I will post the pics
