amp going into protect
BeAlLsTaR13
eh damn well then try taking ground from amp away form batt and ground it where you grounded the back battery.?
done that, even ran without the back batt grounded.
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
damn. you soldered your terminals on? youve check everywhere for loose connections? try the amp in a buddies car
it is grounded to back batt:
I am going to throw my 2 cents in. I had a similar problem . One of my coil leads came unstitched right where the tinsel lead meets the cone. Very hard to see with the naked eye. When playing the system I could not notice one coil was not playing out of the 4. Then, all the sudden the tinsel lead would get lucky and touch. This would cause the amp to see an unexpected impedence drop and go into protect. I only figured it out by taking the sub, hooking each coil up seperatly to my multimeter and would push on the cone. Trying to break continuity. My subs at resting seemed fine but when the sub cone moved the tinsel would lose contact. Maybe, worth looking at.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
try free airing the subs to see if you notice anything funny
thanks for the input, deffinatly seems reasonable guess i'll be pulling the subs tomorrow eh?
Team Sundown Audio
yezzir, solder > crimp anyday
i would try the amp in a buddies car if i had someone who had good enough electrical to back it up haha, what ima do is the civic has lvl 3 d4s, gonna run wires from my amp to his box, test and then run wires from his amp (ed nine.1) and test
i could try that as well, looks like since today was all electrical day, ill put another 9hours to subs tomorrow
Team Sundown Audio
sucks pulling subs out and in dont it lol
35lbs + each, so yup especially one handed, the first one in and the last one out is always the easiest though.
Team Sundown Audio
try it with a 60ish pound 12 fi btl where the magnet is basically bigger then the cut out.. pain in the ASS
  • Who's Online   0 Members, 0 Anonymous, 1290 Guests (See full list)
