well i have a trunk car, and can put up to a 5 cube box in there. i heard to put them in 1.75 per sub, which i can do. so i was thinking 1.75 per sub tuned to 33hz with a slot port. subs in one chamber and port to side. i have a autotek 1900 and i would wire at 1 ohm (dual 4s) and that amp supposibly does rated at 14.4v but i rest at 13.5 and drop down to 12.9-13.1 at full tilt. so im prob gonna set gain to 1800rms at 1 ohm (with dmm) and after rise and volt drop it should be close to sub rms, atleast not to much over powering. i heard these subs are beasts lol but what would you reccomend? iwant to kill the lows.
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
thats perfect
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
i heard they like 2.25 if its right at 600rms?
1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz
* Tune higher for more SPL oriented setup
* enclosure can be as big as 2.25 ft^3 if you stick with the 600 RMS rating
quoted off this site http://www.diymobileaudio.com/forum/diyma-vendors/58437-sundown-sa-12-d4-pre-sale-$175-down-qty.html
I wouldn't make it that big
1.5-1.75 per sub ftw
this.
dont do anymore than 1.75 per sub
Team Sundown Audio
you will see better results with 1.75, the 2.25 is the absolute MAX
Team Sundown Audio
i was going to do 2cu each but the guy im getting subs from said 1.75 would be best just wanted other opinons
he's correct.
Team Sundown Audio
alright thanks
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
