well i have a trunk car, and can put up to a 5 cube box in there. i heard to put them in 1.75 per sub, which i can do. so i was thinking 1.75 per sub tuned to 33hz with a slot port. subs in one chamber and port to side. i have a autotek 1900 and i would wire at 1 ohm (dual 4s) and that amp supposibly does rated at 14.4v but i rest at 13.5 and drop down to 12.9-13.1 at full tilt. so im prob gonna set gain to 1800rms at 1 ohm (with dmm) and after rise and volt drop it should be close to sub rms, atleast not to much over powering. i heard these subs are beasts lol but what would you reccomend? iwant to kill the lows.
thats perfect
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
i heard they like 2.25 if its right at 600rms?
1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz
* Tune higher for more SPL oriented setup
* enclosure can be as big as 2.25 ft^3 if you stick with the 600 RMS rating
quoted off this site http://www.diymobileaudio.com/forum/diyma-vendors/58437-sundown-sa-12-d4-pre-sale-$175-down-qty.html
I wouldn't make it that big
1.5-1.75 per sub ftw
this.
dont do anymore than 1.75 per sub
Team Sundown Audio
you will see better results with 1.75, the 2.25 is the absolute MAX
Team Sundown Audio
i was going to do 2cu each but the guy im getting subs from said 1.75 would be best just wanted other opinons
he's correct.
Team Sundown Audio
alright thanks
  • Who's Online   0 Members, 0 Anonymous, 474 Guests (See full list)
