I did tune the gain, i put it to about 3 out of 11 ..
What im asking is if this is safe?
If i have it any lower than 3, then i get virtually NO Bass out of the Amp ..
3db is what sounds good, just dont wanna blow the sub ..
Do you have a DMM? If you don't you can buy them for about $10 for a cheap one which will do the job. Then find the right voltage for the wattage and ohm load that you are using (there is a chart somewhere, if you tell me the ohm load I can tell you the voltage) and put the dmm probes across the sub and play a 50hz test tone and turn the gain up until you get the correct voltage.
Edited by bassl0va
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
  • Who's Online   2 Members, 0 Anonymous, 1322 Guests (See full list)
