Mechman Alternators
2001 Tahoe 5.3 quotes
That would work for short demos if your brought the engine RPMS to about 1800 rpm. I would probably go with at least 8 D1600 batts if it were me.
Edited by MECHMAN
ok then 8 batts and one alternator be enough for 2000 amps of current
20,000 watts does not generally require 2,000 amps, unless the amps are extremely in-efficient. Most class d amps would use around 80 amps per 1000 watts, making your load around 1600 amps, but there are exceptions to every rule....
  • 2 months later...
any holiday discounts going on @ mechman???
01 Tahoe
Big 3
20 ft.1/0 streetwire under hood
4 Batteries
Stock Battery and
1800 Kinetic Batt under hood
2 Sprinter S12V500F Battery,165 AH
Kicker 1/0 going from front to back
Sirius sportster
Alpine 9886
Kicker 650.4zx mids and highs
Q-Logic kick panels w/Kicker6 1/2 comps.
XXX re comp 6.5 in front doors
Alpine6.5 coax in rear doors
2 Audioque 2200d strapped
2 Audioque 18 HDC3
5% all the way around
2 layers raamat on roof
doors covered in raamat
I don't see alt companies mentioning the fact that an alt rated at 270 in the 14 volt range won't do 270 amps at 16 volts or even 18 volts, it will be lower. Unless you change the properties of the alt, the components it is made of for 16 or 18 setup to do 270 amps.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
As charging voltage increases, so does the field voltage supplied to the rotor. Depending on the unit and it's magnetic properties, some units can actually do a little more amperage at higher voltage levels, but it depends.
Our 270 amp ES will still do 270 amps running on a 14 volt battery.
  • Who's Online   0 Members, 0 Anonymous, 1707 Guests (See full list)
