blcrocker Posted September 9, 2010 Report Share Posted September 9, 2010 I have an 01 Honda Accord and my rear deck shacks and rattles like crazy. Whats the best way to prevent that or at least help. It makes my system sound crappy and I can't stand it. So anything would be nice. Also, What kind of foam should I use to stop most rattling in the trunk lid and spoiler. Quote '01 Honda Accord EX 4 Cyl4/18/13 Started new build Headunit: JVC kdx250bt Sub Amp: Hifonics Hifi 2000d Door Amp: Rear Amp: Sub(s): SQ HDC3-12 Battery(s): Stock Wire: Knu 1/0 and 4awg Big3: Link to comment Share on other sites More sharing options...
TeejayBee Posted September 9, 2010 Report Share Posted September 9, 2010 second skin Quote Link to comment Share on other sites More sharing options...
Kranny Posted September 9, 2010 Report Share Posted September 9, 2010 second skin on rear deck and trunk lid. no need for deadener on the spoiler since its attached to the trunk. no trunk rattles = no spoiler rattles. Quote Link to comment Share on other sites More sharing options...
fox_racin4 Posted September 9, 2010 Report Share Posted September 9, 2010 seal rear deck from trunk will stop most of it then you can wedge cardboard between window and the back deck and that will get ride of it more then likely Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
55437Audio Posted September 9, 2010 Report Share Posted September 9, 2010 What's wrong with peel and seal and spray foam if you want to go the cheap. Not as clean way? Quote My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em' Link to comment Share on other sites More sharing options...
Tek Posted September 9, 2010 Report Share Posted September 9, 2010 What's wrong with peel and seal and spray foam if you want to go the cheap. Not as clean way? you'll get mixed reviews on Peel and Seal. Some say it's not as durable and you need several layers to compare to one layer of Second Skin. I would use it on my floor in a heart beat though since you don't have to worry about it sagging down and it really is cost efficient. Quote Link to comment Share on other sites More sharing options...
superdave07 Posted September 9, 2010 Report Share Posted September 9, 2010 (edited) peal n seal works wonders if your on a budget. I'd go peal n seal, some spray foam, and be done with it. I had the same issue in my 94 accord, doesn't rattle at all now put some p&S on the trunk lid. spray foam up in the bottom side of the package tray to get rid of the sheet metal noise. and you might try to P&S the front side of the seat rest. (The metal that the rear seat lays against) that really should cover it unless you upgrade the whole system... Edited September 9, 2010 by superdave07 Quote Xterra * 69 Camaro * Audi S5 36 Ford * 51 Mercury looking for wire sponsor www.flyracing.com Link to comment Share on other sites More sharing options...
blcrocker Posted September 10, 2010 Author Report Share Posted September 10, 2010 Well since im a college student funds are pretty tight. SO ima try out some P&S and spray foam. I can get all the at lowes right? Quote '01 Honda Accord EX 4 Cyl4/18/13 Started new build Headunit: JVC kdx250bt Sub Amp: Hifonics Hifi 2000d Door Amp: Rear Amp: Sub(s): SQ HDC3-12 Battery(s): Stock Wire: Knu 1/0 and 4awg Big3: Link to comment Share on other sites More sharing options...
55437Audio Posted September 10, 2010 Report Share Posted September 10, 2010 (edited) Ya or home depot. Peel and seel I think are lil rolls of kinda thick paper that is sticky made by protecto wrap if I'm correct. Edited September 10, 2010 by 55437Audio Quote My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em' Link to comment Share on other sites More sharing options...
blcrocker Posted September 10, 2010 Author Report Share Posted September 10, 2010 How should I seal off my rear deck from the trunk? Just get a piece of wood, cut it to shape, and bolt it in? Quote '01 Honda Accord EX 4 Cyl4/18/13 Started new build Headunit: JVC kdx250bt Sub Amp: Hifonics Hifi 2000d Door Amp: Rear Amp: Sub(s): SQ HDC3-12 Battery(s): Stock Wire: Knu 1/0 and 4awg Big3: Link to comment Share on other sites More sharing options...
