55437Audio Posted September 9, 2010 Report Posted September 9, 2010 I'm terriibley sorry if you guys have answered this a few times but how do I find out what the physical tune freq of my cab is. It's a ext cab f350. Thanks, Austin. My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
Red-navi-916 Posted September 9, 2010 Report Posted September 9, 2010 im gonna go ahead and say 46hz... other then that ill wait on bill or hank BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
Boon Posted September 10, 2010 Report Posted September 10, 2010 im gonna go ahead and say 46hz... other then that ill wait on bill or hank Wat. I'm not entirely sure if you're being serious or not ;o It depends on like a million things - have you deadened it, how big is the box, do you have seat covers, what position is the box in, what position are the seats in, how do you have the sun visors placed, is the glovebox open... You have to chuck everything in there and sweep it with a termlab, with the box's port sealed off. That way it should give you a representation of the cabin gain. That's the only way to know your true resonant frequency for any given setup. Some guys I know could change their peak by 10hz just from moving their box around. 10.x volts fo' life!
55437Audio Posted September 10, 2010 Author Report Posted September 10, 2010 Wow. So pretty much a term lab would have a setting to check what the cab freq is at? I could get all the info too.. But a tl would do it too? My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
55437Audio Posted September 10, 2010 Author Report Posted September 10, 2010 Double post. Sorry! My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
Boon Posted September 10, 2010 Report Posted September 10, 2010 Wow. So pretty much a term lab would have a setting to check what the cab freq is at? I could get all the info too.. But a tl would do it too? Yes. You put it on peak hold, run a 30-80hz sweep through your system then open the numeric data window and it shows you the Peak Frequency. 10.x volts fo' life!
Lynbo Posted September 10, 2010 Report Posted September 10, 2010 Like Boon says to run a sweep, just wanted to add a few more things somewhere don’t remember so some of the numbers maybe off. Ready here we go use a 10” sealed sub in a sealed enclosure built to manf. specs, you do not need to over power this sub rms or under is fine. Run the first of two test in an open space with the speaker supported above the ground at least 2 feet and sub facing the mike which is 3 feet away but facing the speaker and run the frequency sweep. This will give you or show you a baseline reading of any peak frequencies that the speaker may have on its own. Now run the second test in your vehicle in your example F350 ext. cab you will place the sub on your rear seat with the sub facing up. Run the sweep again then compare the two sweeps and you should see a difference or peak(s) that is from your vehicle. If I remember right the test should be at same volume for both test to have as close a comparison as possible. This should get you close to your cab frequency but remember that any changes be it damper material applied, removing seats and installing sub-enclosures would change the cab frequency. The changes you make to the interior will change the cab air space or the sheet-metal vibrations, you will have to retest again but you should be close. Depends upon what your goals are with your truck.
55437Audio Posted September 10, 2010 Author Report Posted September 10, 2010 I understand fully. Thanks guys. My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
