so, im wanting to rebuild my motor and i would like to get some more power out of it... i was wondering what i can do... cams or what?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
built 350. jooo can doooo eeeeet :D do the simple boltons.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Crate motor from edelbrock!!!
For real tho a good place to start is your intake and Exhaust system.
Good intake manifold and Exhaust manifold ( or even better perfromance headers )
Posted (edited)
i think hes only got a 4 banger so.. cant do a 350 in it simply haha
id do exhaust and intake then port and polish head
Edited by fox_racin4
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
How far are you gonna go with it. You could have the block machined, new deck height, bore the cylinders to a bigger bore, get a crank with longer stroke, agressive cam, CNC heads. It goes on and on.
<>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
easiest way is add stickers not only do they add 10ish hp each its rumored they give an extra 2-3 DBzzz
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Posted (edited)
Intake and Exhaust Manifolds, complete new exhaust system, cold air intake, port and polish, new pistons, etc...... basically the whole shebang.
Oh wrap ur headers in that heat tape so it will keep the heat in and not let it go everywhere else.
Edited by cubs_fan0718
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
i dont want to do anything too extreme... just something to make it slightly obvious that its more powerful than stock... exhaust and header and intake are a given...
heres what deal is... the piston rings are worn out... she smokes pretty good when i get on it hard... and it burns about a half quart of oil per week... it does run a tad rough... i mean just barely... it kinda sounds like its missing so im thinking timing chain
3 Kinetik Hc2000's
Dual 200amp alts.
Intake and Exhaust Manifolds, complete new exhaust system, cold air intake, port and polish, new pistons, etc...... basically the whole shebang.Oh wrap ur heads in that heat tape so it will keep the heat in and not let it go everywhere else.
i have NEVER seen that.... headers wrapped in header wrap yes heads no and ive seen some pretty high HP cars......
try running thicker oil to help with the oil burning
id so a nice free flowing exhaust and intake and if you pull head off port and polish it
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
