I've been gathering some supplies for a few weeks and I've gotten great service from all three companies.
Pair of Level 3 10s from boss man Rusty at DC Audio as well as an XP Alt from DC Power
and a complete stinger amp kit as well as terminals and volt meter from Darvex.com!
BTW If you put "meade" into the promotion/coupon area you STILL get the SMD member discount! Thanks Darvex!
I'm looking forward to getting everything in and running to full potential!
-Drew
uhoh_45 said:
I'll have updates on the box after the weekend- the winning design is this:
simple 1cuft @40hz per chamber
-Drew
Its not in two sections- its moved.
I left the old tab by mistake- I've been off the mod controls for a while :D If you click on the one in the OT it will just fwd you to the review.
and would they get in trouble? maybe- Not sure I'm still playing catchup with the current happenings of SMD. I think two identical threads is not cool though
-Drew
why 4g? :o
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
BXI1606 only as 4ga power/ground
Keeping this one nice and simple- the Mirage gets the 0000 Hannah and her Jetta get the 4ga lhaha
-Drew
Its not the 1.8T its the 2.0 BUT its a stick and still a blast to drive around- should be even better with a lil bump in zee trunk
-Drew
any reason why the design is like that? sorry im a box noob lol why dont you just mount subs normal lol or is that design more efficent?
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Just another way of loading the woofers- Like a smaller scale version of a vertical clamshell. I chose 10s so that I could play with the design and end up with something just a little different than the usual style box. I'm hoping to artificially boost the low end response, we'll see what happens :D
-Drew
  • Who's Online   0 Members, 0 Anonymous, 1898 Guests (See full list)
