michigancapri92 Posted September 17, 2010 Report Posted September 17, 2010 friend of mine just got some dual 12 inch subs for 20 dollars in a box with 500 watt amp and it all works and sounds nice but the previous owner decided to not know how to use a screw driver or gun when he owned the speakers and there are 2 holes in the ruing from screw driver .... how can you fix those or where is a place that you can send them in to be repaired ??? spent little on them and wants to not spend alot of money on them. Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
Loudcivic Posted September 17, 2010 Report Posted September 17, 2010 well since the speakers are cheap just take some silicone and put it over the hole 2015 silverado crew cab nothing atm but soon...
michigancapri92 Posted September 17, 2010 Author Report Posted September 17, 2010 ok is that rubber type material would that work ? any thing i can cover of it to make look somewhat good ? Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
bassl0va Posted September 17, 2010 Report Posted September 17, 2010 Paint? It does seem like paint would look pretty ghetto though. You could just invert mount the subs, then you won't see the cones. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
onelivinlarge Posted September 21, 2010 Report Posted September 21, 2010 ok is that rubber type material would that work ? any thing i can cover of it to make look somewhat good ? heres what i did for the hole in my polk dbs. go buy from your sports store black rewrap its foamy and then just some plain super glue. cut your piece of the pre wrap lay on hole and put lots of glue on it and seals it right up and once dry repeat like 3 for really good strong repair works great and less then a 10 buck fix(but make sure u get glue on all the pre wrap u put on it 1) lookj to left 2) NOTICE BLKUE 3) ME > Y9OU 4) that is all
