Okay guys just got my Memphis 1/0
Bout to do the big 3, now my question is should i use the strut tower bolt?
Here
Or the current location of all the grounds?
The reason i ask is there is a BIG ASS rubber boot and plate under that strut bolt...
sand down the factory spot then there should be a bolt that holds ya coil pack to the block
so one ground to the inner fender andone wire to the bolt that holds ya coil
Team DBs (Driven By sound)
i dont really like either spot. i drilled and tapped my own hole on a thick piece of metal.
Strut tower is a pretty good ground....however do not take off the center bolt just use one of the 3 or 4 bolts surrounding the center bolt.
¿ǝɯɐƃ ǝɥʇ
Well those are the 2 spots that i have to work with...
As far as the ground on the engine block there are plenty or spots right by the batt i can use...
jeeps are uni bodied there for if he uses the factory bolt still a chassis ground just make sure its bare metal
Thats what i was thinking!
As far as it being bare metel...
Wire brush on a drill FTMFW!!!
:lol:
Haha what the fuck, did nobody here look closely at the 'strut tower' ground option? The lug is hanging off the top of the freakin' strut itself, not the strut tower. You would probably struggle to find a worse ground path...
10.x volts fo' life!
:lol:
That was just sitting there so it wouldnt fall down...
I just did the big 3 and took off all the paint...
Wire brush on a drill made easy work of it!
But thanks everyone for there input!
:drinks:
