benz280se Posted September 20, 2010 Report Posted September 20, 2010 i just had my alt rebuilt by a local shop and it's charging 14.8v @idle. before it was charging at 13.5 @idle. the alt was i think either 80 or 100amps. when the alt was rebuilt did the amperage stay the same? or would he have had to raise the amps also to get the higher voltage?
smokeumtires Posted September 20, 2010 Report Posted September 20, 2010 Sounds like an alt windings job.....or he adjusted the internal regulator
benz280se Posted September 20, 2010 Author Report Posted September 20, 2010 not sure about the terminology but i know he had to completely rebuild it cause the bearings went out and messed up the inside to the point where it locked up while i was driving!
MECHMAN Posted September 21, 2010 Report Posted September 21, 2010 It is fine, 14.8 volts is a good place to be. Your alternator may have been getting tired, and thus only charged in the 13 volt range. 1-888-MECHMAN www.Mechman.com [email protected]
