4th Order in a trunk
IH8PunkRok
im trying to find a new box design for my 3512 (PB 3k for power)
1st idea: standard bass reflex but this time with about 20^2" per cube, 2.5 net volume, 35hz
2nd idea: 8th wave t-line @ 35hz
3rd idea: 4th order, 1 cube sealed 2 or 3 ported, not sure on tuning
basically i need the box to gross about 4 cubes (just to make it fit)
my dimensions are 14hx34wx15d
^ those are rough estimates btw might be more
thoughts, ideas, comments, advice, designs?
let me know guys
obviously i want it to be loud on the meter but i will not sacrifice my music for a number.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I vote for 4th order. Or just for shits in giggles try a normal ported but with something crazy for port, like 25sq inches.
ive been having trouble making it work
i cant make the tuning and net volume where i want them
i think that would be easiest though
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
will a huge port create unloading problems or no?
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
it makes sense that it would. however bkolfo says that the port area is based on woofer not box.
i know that like 75" is less than what the max port area i could have is. therefore i may be safe. id assume my f3 would be a lot more sensitive though
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Them things are trial and error from what ive heard. Also try getting ahold of 8 0inches, or singer. Im sure they could come up with something for you.
Do a DD box. Simple, effective.
Or a 6th order.
Don't do a phase box, DD's don't like them. Well, they only like bass-reflex horns.
4th order = best box ever for a musical 2500 but not for a 15/35/95
10.x volts fo' life!
Or a 6th order.
my box is currently built to DD specs except i have 14" per cube instead of 16 like they advise
should i try and get my port area up and just leave it?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
What's wrong with your current box? I've found that the DD design is a damn good compromise between output and quality. Anywhere from 12-18 inches of port works great.
Since you're running plenty of power you could possibly decrease the box size and increase the port area a little, basically what you're suggesting, but I don't think you would gain much. Slightly under 2 cubes would work well IMO.
  • Who's Online   0 Members, 0 Anonymous, 451 Guests (See full list)
