Big Papa Posted September 23, 2010 Report Posted September 23, 2010 hook an amp up to an oem radio? I know its possible I just don't know how. As far as the remote wire and rca's. 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
Hugh G. Rection Posted September 23, 2010 Report Posted September 23, 2010 hook an amp up to an oem radio? I know its possible I just don't know how. As far as the remote wire and rca's. you will need an LOC, and possibly a ground loop isolator. most folks would just wire the remote from a switched wire at the fuse panel. not my preferred method, but it works........ Owner of BigAss Ports
dugee81 Posted September 23, 2010 Report Posted September 23, 2010 what sonic elec. shows for OEM integration 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
Big Papa Posted September 23, 2010 Author Report Posted September 23, 2010 what in thee hell is an LOC? and where would I be able to find those things? 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
hdorre Posted September 23, 2010 Report Posted September 23, 2010 Line output converter for RCAs and a switch from the battery positive to amp remote. You could tap into the cigarette lighter or ignition if you don't want the switch On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Big Papa Posted September 23, 2010 Author Report Posted September 23, 2010 after looking at loc's it looks like im just gona get an aftermakret h/u and suck it up and spend 75 bucks on a dash kit. 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
dugee81 Posted September 23, 2010 Report Posted September 23, 2010 after looking at loc's it looks like im just gona get an aftermakret h/u and suck it up and spend 75 bucks on a dash kit. i think some places send out H/U's with a wiring harness & dash kit 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
Big Papa Posted September 23, 2010 Author Report Posted September 23, 2010 i have a taurus and the heater controls and radio are one piece. This is what I need. http://www.sonicelectronix.com/item_9154_Metra+99-5717.html 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
