I would honestly say just run 4awg to the back, tap into that for the HU as well as the amp. Pos+ & rem go to the power wire, neg- to the ground. Those are the only 3 things u need. Then get a 3ft rca cable for the amp that will be next to the HU. Simple as that.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
thats what i was gona do and if i cant sell my d3400 ima put it in the back for it im only running 500watts lol
Yeah dude. Jus run the wires to your d3400 and connect the hu to that as well as the amp. Hell, like you said you're only running 500wrms, just throw that battery in the back and don't worry about running wire thru the car
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
So this is all i got do .
If i just use her stock batt.
Wire the 4g wire from the front to back for the Amp
then i can take the power wire for the headunit to the pos part of the amp and same for neg then just jump the pos wire to the rem wire spot and put the Rca's to the amp and blahhbamm im good to go correct?
Sounds right. Alot of people take like a 4 pin molex connector like the ones in a computer. And make like a plug. so the power, and neg are wiring into a female molex coming from the amp, and a lil set of rca's using female to female conectors at the end from the amp.
From the h/u power/rem wired together, and neg into a male molex and another set of rca's coming from the h/u.
when you wanna bump just plug the plugs together,when your done just unplug. just like plugging something into the wall at home :P
edit: you could even rip up the rca's have the first two pins in the molex for h/u power and ground and the last two pins for right and left channel and wire the grounds with the other ground and just have a simple lil four pin plug. i think that would work, but idk about the quality of the signal :P i think that would be good?
Edited by P4killer_
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
