Skip01 Posted October 8, 2006 Report Posted October 8, 2006 Ok ok...soo lets say the setup 4 SS PCA2000 on 2 12 FI BTLs Soo lets say i get the Dual 2dvc and i wanna strap 2 amps on each. Now i i have 1 amp and wire it parrellel i will get a 1ohm final load. What if i wire it parellel and have to amps strapped to it...what will each amp see.... .5ohm? And what power will they put out...if strapped with sub in series will it see a 1ohm load but put out more than just 1 amp seeing a 1ohm load?So more than the 2000watts@1ohm its rated at normally? Thanks...any info i can get...or anything im skipping over let me know? 2004 Explorer4 12" Type R500.1(.5 ohm)6cu@35hz153@ 44hz
BumpinLow Posted October 8, 2006 Report Posted October 8, 2006 The dual 2's are really 1.5 coils, so it'll be wired to a .75 ohm load, but then each amp is seeing .375 I believe which I dont know how those amps will do @ that low of an ohm load. My suggestion is to just not strap them and run one on each coil, they'll each be close to the rated watts, shouldn't poop on you and I think it will be less of a hassle. Only my opinion tho
Guest 90accordman Posted October 8, 2006 Report Posted October 8, 2006 they wont like it at all being strapped
Skip01 Posted October 8, 2006 Author Report Posted October 8, 2006 Soooo what about dual 1s and just 1 to each coil that would be best. 2004 Explorer4 12" Type R500.1(.5 ohm)6cu@35hz153@ 44hz
SPLGEO Posted October 8, 2006 Report Posted October 8, 2006 as far as I know when you strap 2 amps together you have to divid the ohm load by have..... such as 2 1ohm stabe amps strapped you can only run tehm at 2 ohm but you ad the 1 ohm powers together 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
meade916 Posted October 10, 2006 Report Posted October 10, 2006 you are correct GEO.... All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
