THEKINGsBACK Posted September 26, 2010 Report Posted September 26, 2010 ok well i had a problem before trying go get a dual battery setup going. Now well i got 1 new kinetik and my red top up front and i know that i will need to have at least two battery's or my voltage will smoke the amp from being to low. my question is well i have few 1 how do u post pictures of things.. and 2 how do i make it so that the kinetik and the optima work together because i don't have the funds to try and get 2 new battery's so i wanna make sure that this is done right and will work at least till i can get my other kinetik 1800 back or i have enough saved for 2 xs power 2400s he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Socky Posted September 26, 2010 Report Posted September 26, 2010 Run 2 runs minimum to the rear battery, 1 positive, 1 negative. Run them parallel. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
THEKINGsBACK Posted September 26, 2010 Author Report Posted September 26, 2010 Run 2 runs minimum to the rear battery, 1 positive, 1 negative. Run them parallel. ok and should i charge both of them prior to doing this? he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Socky Posted September 26, 2010 Report Posted September 26, 2010 As long as they are reading a good 12v charge they should be fine, your alternator should keep them charged. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
THEKINGsBACK Posted September 26, 2010 Author Report Posted September 26, 2010 As long as they are reading a good 12v charge they should be fine, your alternator should keep them charged. see thats were i get confused. because i did it that way the first time and one of my kinteiks would like bubble up when connected to the red top.. he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Socky Posted September 26, 2010 Report Posted September 26, 2010 Might have to ask others about that, ive seen others run the yellow top and kinetics. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
THEKINGsBACK Posted September 26, 2010 Author Report Posted September 26, 2010 Might have to ask others about that, ive seen others run the yellow top and kinetics. yea its crazy... i dont get it... may have to pay a professional.. and damn i dont wanna do that.. he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
THEKINGsBACK Posted September 27, 2010 Author Report Posted September 27, 2010 ok well i had a problem before trying go get a dual battery setup going. Now well i got 1 new kinetik and my red top up front and i know that i will need to have at least two battery's or my voltage will smoke the amp from being to low. my question is well i have few 1 how do u post pictures of things.. and 2 how do i make it so that the kinetik and the optima work together because i don't have the funds to try and get 2 new battery's so i wanna make sure that this is done right and will work at least till i can get my other kinetik 1800 back anybody else??? he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
