DC Sound Lab
I reconed my XL 12 and shimmed it like all the other recones I've done and all glue joints were done perfect to my knowledge. The subs plays fine till a certain volume and the makes a mechanical noise like bottoming out but it never did before and it has an extra spider this time. Also I have the 2 subs on 2 sundown 2000s and I broke my dmm so I can't check to be sure if they are putting out the same power. Any help would be appreciated thanks.
dc lvl 4xl 12
kicker zx1500
2 sets of kicker ds6.5s
optima yellow top (extra batt) with big 3
1/0 guage and 3 150amp anls
eclipse cd5000 headunit
are you playing below tuning? O.o and might wanna get a DMM
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
First, link the amps (if the impedance is fine) if the subs are in the same box. If you don't have a DMM, either buy one, put the amps in different boxes, or recone the subs so you can link them
Do you smell smoke..you may be clipping. Or maybe playing low frequencies
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Dmm is broke so I will have to get another and subs are dual 1s wired at 2ohms for break in, at comps I was planning on wiring at .5ohm, the one I reconed did fine on the single amp at .5ohm though. More input on strapping amps, noob to that.
dc lvl 4xl 12
kicker zx1500
Make sure your subsonic is set right i use to get that problem with my dds could be your box is unloading causeing over excursion
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Well its only the one sub and no I don't freeair my subs, it is the farthest from the port tho
dc lvl 4xl 12
kicker zx1500
Please chime in if you can advise me on strapping the amps
dc lvl 4xl 12
kicker zx1500
Already resolved that issue, epoxied the dustcap myself
dc lvl 4xl 12
kicker zx1500
  • Who's Online   0 Members, 0 Anonymous, 2567 Guests (See full list)
