C-fizzy's 18" sub build. HAIRTRICK 1/31
The tensioner bolts are on the front, their not a problem. The support bolt is in back, that's the soft one. MAKE SURE, you use a tight fitting socket or wrench and regrease before reinstalling (wirebrush the threads if you can). It'll save you about 9hrs worth of intense swearing, busted bleeding knuckles, hand filing, and a trip to the hardware store for a new one (you could replace with a high grade one now if you want, i recommend this). I even knew to do this prior, but I got too excited and lazy when installing it the first time. Even with a perfect fitting 6-sided socket, I turned the hex head into a round head when I went to take it out for new belt.
Listen to this man! I do shit like this at my work more than you'd expect...
Get some PBBlaster. It is penetrating fluid, works fucking WONDERS. Use it, use lots of it!
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
thanks for the advice man.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
I had a 15" BL back in the day.
You're gonna need to squeeze every inch out of that car for your wall
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
Thats on a 1500?!
DAMN!Im getting pretty pumped for my build!!!
BTW check your tires bro. Look extra flat.
Haha they're not flat, i was just sunk in the mud a little bit. but yup, one 1500.
oh, and thats nothing, i found that my car LOVES 28 hz, but my hatch hates it :)
under construction
u hate c-fizzy?
I thought they were, but i figured id throw it out there.
And i still don't know what to do about my car. But i have made a few joking suggestions about one thing that is looking more and more possible day by day.
Tercel build R.I.P.
V-Dub
My feedback.
What idea do you have?
under construction
u hate c-fizzy?
oh i forgot about the alt update LOL.
but does anyone want a REAL update? :)
i dont care if you do or not. pics will be up in 30.
under construction
u hate c-fizzy?
30? hurry up already :clapping:
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
