OkanaganDCaudio Posted September 30, 2010 Author Report Posted September 30, 2010 http://www.modifiedlife.com/2001-gmc-jimmy-car-radio-install-diagram/ For any other dum newbs like me
OkanaganDCaudio Posted September 30, 2010 Author Report Posted September 30, 2010 what would it be best to connect my red & yellow wire to that is hot ?
MrSkippyJ Posted September 30, 2010 Report Posted September 30, 2010 what would it be best to connect my red & yellow wire to that is hot ? Do you have a factory harness in the car now? Like the one that plugs into the back of the factory radio? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
ingramcaraudio Posted September 30, 2010 Report Posted September 30, 2010 Give some details do you have a plug kit if not what kind of car is it. Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts
OkanaganDCaudio Posted September 30, 2010 Author Report Posted September 30, 2010 2001 GMC Jimmy SLE, No plug kit.
MrSkippyJ Posted September 30, 2010 Report Posted September 30, 2010 2001 GMC Jimmy SLE, No plug kit. You mean the factory harness is gone? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
OkanaganDCaudio Posted September 30, 2010 Author Report Posted September 30, 2010 You mean the factory harness is gone? the harness is there, the wires are plugged into the harness. But they do not have any locally around here for a 2001 jimmy to fit that clarion plug-in the guy said. That is why i spliced, I left lotsa room on the wires i cut from the stock harness incase i ever find its match i can splice the wire back together. Right now all i get is red light flashes, Thats the constant sign right ? So it must be somthing to do with the other wire that controls if it turns on or not right ? I think im finally getting this hole deck installation thing lol. I was unable to plug-in the long radio clip the one wtih my vehicle is much shorter & was normally bent. I think i will have to get a differant plug end for it, But outside of that i think everything went fine it fit in real nice & smooth when i put my dash back on when this is done i think it will look nice.
ingramcaraudio Posted September 30, 2010 Report Posted September 30, 2010 Ok when you strip your wires find a wire that lights up all the time using a test light that will be your constant then turn the key and find which wire lights up that will be your red or switched Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts
OkanaganDCaudio Posted September 30, 2010 Author Report Posted September 30, 2010 http://www.youtube.com/watch?v=AgZB3YcaI1A
MrSkippyJ Posted September 30, 2010 Report Posted September 30, 2010 the harness is there, the wires are plugged into the harness. But they do not have any locally around here for a 2001 jimmy to fit that clarion plug-in the guy said. That is why i spliced, I left lotsa room on the wires i cut from the stock harness incase i ever find its match i can splice the wire back together. Right now all i get is red light flashes, Thats the constant sign right ? So it must be somthing to do with the other wire that controls if it turns on or not right ? I think im finally getting this hole deck installation thing lol. I was unable to plug-in the long radio clip the one wtih my vehicle is much shorter & was normally bent. I think i will have to get a differant plug end for it, But outside of that i think everything went fine it fit in real nice & smooth when i put my dash back on when this is done i think it will look nice. ok, so you cut your factory harness out of your truck? the wiring harness you buy has nothing to do with what head unit you are installing and everything to do with what model and year your car is. what red lights flash? lights on the clarion? what is the long radio clip? what does it do? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
