Mechman Alternators
rewind my irragis
I have a 220 and 2 280s iraggi alternators. im happy with the 220 somewhat. but the 280s suck yhey have no output at idle. i want the most output at idle for burps and demos. what can you offer me as a solution and how much? ill probably send you one at a time or both 280s. im not rich so a reasonable price and im there thanks
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
THey are the same style as steves just 280s they have the 4pin oval connecctor. what would be output at idle? im pretty sure they are cs130s
Edited by dc98hoe
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Steves alts are AD244 units, not CS130s. Assuming your units are AD244, we would charge $150 each to put in our solid copper rectifier (for duarability) and our 270 amp stator. Our 270ES unit does 165 amps at idle. That price assumes that all other parts in the unit are good, and does not include any other parts that may need to be replaced.
  • Who's Online   2 Members, 0 Anonymous, 707 Guests (See full list)
