civicman Posted October 24, 2010 Report Posted October 24, 2010 Oh. snap thats only a few hrs away, I better get some sleep to make it too!! See everyone there, Have a safe drive!!! on my to the shop se u guys there late B slap yo mama twice Team Bassick Nyman
cjvue Posted October 24, 2010 Report Posted October 24, 2010 I'll be your friend if you pay my entry fees oh ya, btw guys, midwest SPL is free for the 1st class and 15 or 20 for a second class. jealous? lol Skittle, come down and i'll pay you in!... But goddam i'm very dissappointed right now. got to babIES sit. I role by earlier and peeps there already! My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio
sactownstang Posted October 24, 2010 Report Posted October 24, 2010 cold and wet but all went down perfect!
AA98hoe Posted October 24, 2010 Report Posted October 24, 2010 cold and wet but all went down perfect! what was your score in dbdrag? TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
AA98hoe Posted October 24, 2010 Report Posted October 24, 2010 im freakn wet as fu.. but i took home 2 firsts,it was a good turnout for bad weather TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
loganberry Posted October 24, 2010 Report Posted October 24, 2010 Not my day, had nothin but problems still put up a good burp score for 1 amp I think My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
AA98hoe Posted October 25, 2010 Report Posted October 25, 2010 great number for your class. what you got in there didnt get a chance to talk to you or check it out. TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
AA98hoe Posted October 25, 2010 Report Posted October 25, 2010 Not my day, had nothin but problems still put up a good burp score for 1 amp I think you put up a good number for one amp. when you get 2 you should get a big number. my door broke and i got a screw in my tire but it was cool TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
sactownstang Posted October 25, 2010 Report Posted October 25, 2010 2 12's..... Ya u shoulda came and said hello...... We usually keep the white car up and playing music, but the rain messed that up. Team SSC represented well Jeff street b 153.1 Dan street c 154.0 Scott ss 3-4 155.3 Ron street max 150.6
